Home Forums Support 404 with require_https and cloudflare
This topic contains 8 replies, has 3 voices, and was last updated by  bbrendon 3 months ago.
Viewing 9 posts - 1 through 9 (of 9 total)
  • Author
    Posts
  • #19567
    CMAW
    Participant
    My site is using a subdomain for invoice ninja http://invoice.mywebsite.com
    The site is hosted with GoDaddy on a shared server.
    I have a Cloudflare A record configured to point to my host IP which will serve the website over HTTPS
    As soon as I turn on REQUIRE_HTTPS=true in .env – I am unable to access the site over HTTPS.
    The APP_URL in .env is set to https://invoice.mywebsite.com
    My site works absolutely fine over HTTP
    Can anyone help?
    #19568
    CMAW
    Participant
    Almost able to resolve my own issue
    Changed Cloudflare SSL type from Full to Flexible
    I get an error:
    ERR_TOO_MANY_REDIRECTS
    If I change TRUSTED_PROXIES in env to TRUSTED_PROXIES=”*” it then works over HTTPS however not recommended
    Can anyone advise how this can be secured?
    #19570
    Hillel Coren
    Keymaster
    If you know the IPs you could specify them rather than use *
    #19571
    CMAW
    Participant
    Hi Hillel, I tried this but got the same issue
    I’m not too familiar with Laravel – perhaps the syntax is incorrect?
    TRUSTED_PROXIES=”103.21.244.0/22″,”103.22.200.0/22″,”103.31.4.0/22″,”104.16.0.0/12″,”108.162.192.0/18″,”131.0.72.0/22″,”141.101.64.0/18″,”162.158.0.0/15″,”172.64.0.0/13″,”173.245.48.0/20″,”188.114.96.0/20″,”190.93.240.0/20″,”197.234.240.0/22″,”198.41.128.0/17″
    #19572
    Hillel Coren
    Keymaster
    I think you have too many quotes, it should be “ip,ip,ip,…”
    #19573
    CMAW
    Participant
    Tried that also but same issue
    I will continue to work on a solution and post here when resolved
    #22296
    bbrendon
    Participant
    Did you figure this out? I’m using nginx (proxy_pass) for invoice ninja and I have only been able to get it work if I specify an (*) asterisk as TRUSTED_PROXIES.
    I tried specifying a single IP address of nginx but that didn’t work. I also tried CIDR notation, also did not work.
    Does anyone know that TRUSTED_PROXIES actually does?
    #22297
    Hillel Coren
    Keymaster
    TRUSTED_PROXIES accepts a comma delimited list of subnets
    https://invoice-ninja.readthedocs.io/en/latest/configure.html#using-a-reverse-proxy
    #22298
    bbrendon
    Participant
    Yea. I tried exactly
    TRUSTED_PROXIES=’10.0.0.0/8,172.16.0.0/12,192.168.0.0/16′
    which is basically *
    …but they don’t work equally.
    After I put the right IP address it worked. Lol. Not sure where I came up with the IP I tried originally. Brain fart.
You must be logged in to reply to this topic.
Posted in:
